20-02-12, 01:53 AM
(Questo messaggio è stato modificato l'ultima volta il: 10-01-14, 05:12 PM da Flaviospeed.)
- Nick del proprietario nel forum: Leoallafila (ho il title da sabato!)
- Nick dell'auto: Madmax
- Casa costruttrice: Ford
- Modello: Gran Torino
- Anno: 1972
- Disposizione e numero cilindri: V8
- Motore: 466 CI
- Potenza: sconosciuta
- Cambio: C4
- Stato dell'auto: meccanicamente e ciclisticamente ineccepibile, mancano verniciatura finale e sistemare gli interni. Ha 2000 miglia da quando e' tornata in strada
- Provenienza auto: California
- Descrizione varia: ZING!
- Foto:
Scheda tecnica attuale:
ENGINE:
466 ci (429 bored 0.30 and stroked)
10.5 comp ratio
TRW forged pistons
Arp Rod Bolts
High Flow Aluminum Water Pump
Pro Comp Harmonic Balancer
Cobra Jet Baffled Oil Pan
DOVE heads ported polished
Cobra Jet titanium valves
procomp full roller rockers
CobraJet/Police Interceptor Exhaust Manifolds
comp cams custom grind camshaft
Cobra Jet valve covers
Weiand stealth intake manifold
fast EZ EFI Fuel Injection
serpentine belt conversion
2.5 inch exhaust with X pipe and Dynomax VT Mufflers and High Flow convertors
all hoses and belts new
Roush plug wires
MSD 6A ignition
MSD Pro Billet Distributor
Aluminum High flow 3 core radiator
Aluminum power steering cooler
140 amp 3G alternator conversion
TRANSMISSION:
C-4 with R servo
2500 PTC torque convertor
B&M Z Gate shifter
BRAKES:
new aluminum master cylinder
front 12 in rotor conversion with new pads, calipers, bearings, seals
flexible stainless steel lines: front and rear
rear drums upgraded to 11 x 2.25 with new shoes, hardware, wheel cylinders
new axle seals and bearings
REAR SUSPENSION:
9 inch rear end
new 3.50 richmond gears
new yukon traction lock
boxed lower control arms
poly bushings (top and bottom arms)
Monroe police spec shocks (â94 Crown Vic)
Coil Spring Specialties 2 in lowering springs
rear sway bar
FRONT SUSPENSION:
Coil Spring Specialties 2 inch lowering springs
all poly bushings except strut arms
new upper and lower ball joints
1 1/8 sway bar with poly bushings and new end links
STEERING:
Mustang Saginaw 3 turn lock-to-lock box
new inner and outer tie rods and connectors
new idler arm
new pitman arm
WHEELS AND TIRES:
Ford FR500 wheels
17x9 front
17x10.5 rear
275 40 17 Eagle Goodyear front tires
315 35 17 Sumitomo rear tires
INTERIOR
scat procomp racing bucket seats
perfect black dash pad
140 mph police certified speedometer
5in autometer tach
grant nascar style steering wheel
new ignition switch/door lock matching key set
"chissà quanto beve!"
"meno di me"
"meno di me"
