1940 Ford Coupe Standard
  • Nick del proprietario nel forum: Blue Oval
  • Nick dell'auto:
  • Casa costruttrice: Ford
  • Modello: Coupe Standard
  • Anno: 1940
  • Disposizione e numero cilindri: V8
  • Motore: Flathead
  • Potenza:
  • Cambio: manuale
  • Stato dell'auto:
  • Provenienza auto: Illinois
  • Descrizione varia: Vi presento la mia 40 e come veniva pubblicizzata al momento della vendita.
Here is a true Hot Rod Survivor! This a nice original 1940 Ford Standard Coupe! This coupe has been stored away since 1972 were it has been in a private collection. This car was built back in the late 50s with a nice Hot Rod look! The car is very straight and solid! The doors open and close like day one, actually better than my new truck! The trunk is the same way, opens like new. The trunk floor is pretty nice with some very light rust in the upper center, the rear pan is very nice, very light rust, even has the wood to cover it yet. The front floors are nice, do have a patch as you can see and a couple spots need a little work. These old 40s will always need a little work in the floors that is just part of there design. This car I drove onto the trailer last year when i picked it up. The car will need to be gone through before you drive it around town, go through the brakes etc. The body is nice, has nice trim, doors are solid, has good glass windows that roll up and down. Front grille is nice and the hood is nice as well. Dash is very nice with a deluxe clock glove department door that was added back in the 50s. Interior is original. For a Hot Rod look they put the shifter on the floor instead of the column, Just a nice custom look. This is a great car and nice survivor! You dont come across them this nice in original condition anymore. This is the black paint that it was painted back in the 1950s. This car would be great to leave original and drive and enjoy. The car is all original not taken apart or worked on! This is what the old moonshiners used for running back in the day this exact car, kinda cool.
  • Foto:
[Immagine: foto200131nc9.jpg]
[Immagine: foto005jm2.jpg]
[Immagine: dscn1598wp8.jpg]
[Immagine: dscn1594hk3.jpg]
[Immagine: foto003fb0.jpg]
[Immagine: foto004kp9.jpg]
[Immagine: foto009hl7.jpg]
auguri! e complimenti per l'acquisto <img src="https://www.usacarsforum.it/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />choiked:
Se la foto fosse un pochino pi? grande...poteri farti complimenti pi? adeguati!
Complimentoni!!!
<img src="https://www.usacarsforum.it/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />choiked: <img src="https://www.usacarsforum.it/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />choiked: :ghghgh:
http://www.funnycar.it/
Stay hungry, stay foolish
COMPLIMENTI!! <img src="https://www.usacarsforum.it/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />choiked: :ghghgh: :ghghgh: <img src="https://www.usacarsforum.it/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />choiked:
[quote name='funnycar' post='162060' date='25/10/2008, 08:50']Se la foto fosse un pochino pi? grande...poteri farti complimenti pi? adeguati!
Complimentoni!!!
<img src="https://www.usacarsforum.it/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />choiked: :ghghgh: :ghghgh:[/quote]
Sinceramente avevo messo due foto ma ho visto che ? intervenuto caddy quindi penso di aver combinato qualcosa come mio solito.
Appena posso faccio delle foto decenti e le posto .
Caddy scusa in anticipo se ti toccher? lavorare di nuovo <img src="https://www.usacarsforum.it/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />choiked:
Grazie a tutti.
Complimenti....sincerissimi complimenti!
Allora ...... la 40 ? sempre stata una delle mie macchine preferite e dopo aver provato la 39 di mopar ? stato impossibile resistere all' annuncio di questo mezzo.
Inoltre, quando ? nata la mia bambina mi ? venuto il desiderio di avere un rod dove starci almeno in 3 , cosa che sulla model A non' ? assolutamente possibile .
L' annucio di chi vende ? sempre abbastanza ottimistico ma nell' insieme considero questa macchina meravigliosa proprio per lo stato in cui si trova.
Il colore originale era marrone e negli anni 50 ? stata verniciata nero lucido. Contestualmente hanno tolto il suo motore originale da 60 cv e lo hanno sostituito con un moldel 59 da 100 cv eliminando anche il cambio a colonna e posizionandolo a pavimento . Nel fare ci? , anzich? smontare la macchina hanno per? tagliato il firewall mentre lo shifter anzich? essere al centro del pavimento in realt? ? posizionato tra accelleratore e freno. Per il resto dopo un po di coccole il flathead ? partito, gira bene, ha un suono fantastico e regge il minimo che ? una meraviglia.
L' intenzione ? quella di smontare cambio e motore per dare una bella pulita e sistemata generale, sistemare il firewall e lo shifter, rifare completamente freni,radiatore, linea benza, gomme nuove, dare una parvenza di vivibilit? all' interno, una sistemata generale a sospenzioni, sterzo ed anche abbassarla un pochino sia davanti che dietro.
Per il body mi piacerebbe lasciarlo nello stato in cui si trova, quindi vernice un po vissuta con qualche sfriso e qualche segno di ruggine al posto giusto.
Nel frattempo continuo a sognare. <img src="https://www.usacarsforum.it/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />choiked:
SPETTACOLO!
Compliments <img src="https://www.usacarsforum.it/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />choiked:
[quote name='bronzo' post='162073' date='25/10/2008, 11:48']Complimenti....sincerissimi complimenti![/quote]
grazie Bronzo ............ quando sar? il tuo momento di lavorare su un rod, chiamami che carico un po di attrezzi ed arrivo. <img src="https://www.usacarsforum.it/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />choiked:
[quote name='Blue Oval' post='162072' date='25/10/2008, 11:46'][quote name='funnycar' post='162060' date='25/10/2008, 08:50']Se la foto fosse un pochino pi? grande...poteri farti complimenti pi? adeguati!
Complimentoni!!!
Grazie a tutti.
Prima di tutto complimenti :ghghgh: :ghghgh: :ghghgh: :ghghgh: :ghghgh:
te li faccio adesso perch? quando ho modificato il topic era notte, ero appena rientrato dal lavoro ed ho giusto messo un po' di ordine
si, c'erano due foto ma se ne vedeva solo una, non ho idea del perch?.
Attendiamo le altre foto! :ghghgh:
Complimentoni!!!
Grazie a tutti.
....se non sei in grado di usare sistemi informatici,ti potrei sempre dare una mano io,cosi' il casino e' garantito!!!!bella bella bella la 40'
Complimenti! Aumenta il tuo parco auto e quello italiano!!!
Complimenti, Bell'acquisto!
veramente bella....molto particolae. Quindi da un neofita super-complimenti.. <img src="https://www.usacarsforum.it/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />choiked:
[quote name='Blue Oval' post='162078' date='25/10/2008, 12:28'][quote name='bronzo' post='162073' date='25/10/2008, 11:48']Complimenti....sincerissimi complimenti![/quote]
grazie Bronzo ............ quando sar? il tuo momento di lavorare su un rod, chiamami che carico un po di attrezzi ed arrivo. :ghghgh:
Grazie....non so quando...ma prima o poi...
ho lo stesso problema di "capienza"....dovr? pensare a qualcosa per almeno 3 persone...quindi presumo anni 40...anche se il 39 di mopar mi fa impazzire...
Ragazzi... se non abitassi cos? lontano starei tutto il giorno in officina a rubare con gli occhi e cercare di imparare il pi? possibile!
inserito un po di foto a pag.1
denghi? :hum:
E' veramente una bella machina conservata!
Complimenti di tutto cuore. :hum: <img src="https://www.usacarsforum.it/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />choiked: <img src="https://www.usacarsforum.it/forum/images/smilies/confused.png" alt="Confused" title="Confused" class="smilie smilie_13" />choiked:
Una delle mie auto preferite. Complimenti di cuore!
Bella davvero!
Io sono riuscito a mettere la mia sotto casa....un sogno che ho aspettato 25 anni per realizzare....foto a breve
