Ora che la macchina ? dal meccanico ho trovato la targhetta con i codici rpo, magari potete darmi una mano per quelli mancanti:
1FP87: Camaro Z28 Sport Coupe, V8
AR9: SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3: LOCK CONTROL, SIDE DR, ELEC
A01: WINDOW, TINTED, ALL SHADED, W/S
A31: WINDOW, POWER OPERATED, SIDE
A90: LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
BS1: INSULATION, ACOUSTICAL PKG
B18: ORNAMENTATION, INTR, DELUX
B34: COVERING, FRT FLOOR MATS CARPETED INSERT
B35: COVERING, REAR, FLOOR MATS CARPETED INSERT
B4E: LT Package
B48: TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B84: ORNAMENTATION, EXTR MLDG, B0DY SIDE
B9K: ORNAMENTATION B/S MLDG REAPPLY TO RR DOORS ONLY
B91: ORNAMENTATION, EXTR MLDG DR EDGE GUARD, COLORED
CD4: WIPER SYSTEM WINDSHIELD, PULSE
C60: HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
D08: PAINT, HIGH GLOSS FINISH
D27: COVER, RR COMPT, TRUNK STOW
D35: MIRROR, OUTSIDE REAR VIEW
D42: SHADE, RR COMPT SECURITY
D6F: ???
D80: SPOILER, RR END PNL
D85: STRIPE, B0DY SIDE LOWER ACCENT
D86: PAINT, TWO-TONE, DELUXE
E5Z: SPEEDOMETER ADAPTER (DELETE)
E7Z: SENSOR VEH SPD - DELETE
E9Z: SPEEDOMETER KEY (DELETE)
FE1: SUSPENSION SYSTEM, S0FT RIDE
GU2: AXLE REAR, 2.73 RATIO
J50: BRAKE SYSTEM, POWER
K34: CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K60: GENERATOR, 100 AMP
LG4: ENGINE, GAS, 8 CYL, 5.0L, 4BBL
MD8: TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO: MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5: EMISSION SYSTEM, FEDERAL, TIER O
NK3: STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
NOD: ASSEMBLY PLANT, NORWOOD, OHIO
N33: STEERING COLUMN, TILT TYPE
PC3: WHEEL, 14 X 7, STEEL
P08: COVER, SUPER DELUXE WHEEL
QDX: Tires, P195/70R14 Eagle GT
TR9: LAMP, GROUP
TT4: HEADLAMPS, HALOGEN, 4
UM6: RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
UQ1: RADIO PROVISIONS, FOR STEREO
U21: CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U25: LAMP, INTR, RR COMPT, COURTESY
U26: LAMP, INTR, ENG COMPT, COURTESY
U29: LAMP, INTR I/P, COURTESY
U79: SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VK3: LICENSE PLATE, FRT MOUNTING PKG
V73: ANTENNA, FIXED
YR1: SEAT,FRT CUSTOM
YS1: SEAT,RR CUST
YT1: BUILD UP DR & QTR
YT9: FLEET PROGRAM EXPOSURE INITIATIVE I: C/F/G/H/J/K/M/N/S/U/V/W/Z- TRK CKGMPST
1AY: Stock Orders Processing Option (DEALER ORDERED CAR)
1SC: PACKAGE, OPTION 03
1SV: PACKAGE, OPTION 20
19Q: MOLDING COLOR (BLACK)
41U: PRIMARY COLOR, EXTERIOR, BLACK
54A: STRIPE COLOR, ACCENT, MED GOLD (91)
6AC: COMPONENT FRT LH COMPUTER SEL SUSP
62C: TRIM COMBINATION, CLOTH, LT SADDLE Â
62I: INTERIOR TRIM, LT SADDLE (I)
629: ???
7AC: COMPONENT FRT RH COMPUTER SEL SUSP
8UZ: SPRING, COMPUTER SELECTED, REAR, LEFT HAND
84L: SECONDARY COLOR, EXTERIOR, HAWAIIAN ORCHID (92)
9UZ: SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
Le foto della macchina sono [url="https://www.usacarsforum.it/forum/index.php?showtopic=13939&view=findpost&p=341570"]qui[/url], notate qualche incongruenza sebbene non sia facile tramite foto?dove posso trovare una dettagliata descrizione di questi codici per capire bene a cosa si riferiscono?le minigonne e lo spoiler anteriore (che non sono di serie sulla LT) sono indicate nei codici o no?scusate le troppe domande!
