1972 Ford Gran Torino Sport (clone "GRAN TORINO" Clint Eastwood)
Motore 351 Cleveland
Stato auto come da foto e descrizione (vedi sotto), molto buono.
Auto negli States (Bellevue, Washington)
$10.000
Ok non è SportRoof, non ha un CobraJet sotto il cofano... ma per $10.000 direi che è un'ottima auto!!!!!!!
Sto cercando un pazzo (o più di uno) che abbia voglia di comprarla e trascinarla qui nel "Bel paese" assieme a me... in società diciamo. VOLONTARI?!?!
[Immagine: 1j7zv6.jpg]
[Immagine: 25krct4.jpg]
[Immagine: 2n8bpcp.jpg]
[Immagine: 2hobgjl.jpg]
[Immagine: rhikbq.jpg]
[Immagine: 262xf1h.jpg]
[Immagine: 357hvza.jpg]
[Immagine: felzr8.jpg]
[Immagine: 5ufkmf.jpg]
[Immagine: 24l37zp.jpg]
Descrizione completa originale:
Its a 1972 FORD GRAN TORINO SPORT with a matching numbers drive train from the 351 Cleveland motor to the C-4 Transmission through to the 2.75 axle. Bone stock and all original this amazing automobile was taken down to bare metal and limited filler was used to get this car extremely straight. This Rust Free car was well cared for by a City of Kirkland Fire Chief for 42 years and this car shows the owner loved and cared and babied this car its entire life.
Ground down to bare metal. Metal conditioned prior to primer. Self etching primer was then applied. A PPG DP-90 sealed, then 5 coats of high build, then block sanded. 2 more coats of high build primer once again and block sanded once again. Then finish wet sanded with 600 grit prior to painting color. PPG Basecoat Clearcoat was applied professionally, have receipts to show and then the laser stripe was applied after paint had a chance to cure totally.
The 351 Cleveland motor, which was rebuilt by previous owner, runs strong and tight and LEAKS NOTHING!!!!! What is that worth to you? Transmission, C-4, was rebuilt by previous owner and leaks nothing and shifts smoothly every time. Power steering, power disc brakes, new alternator, new battery and plugs and wires are also new. The gas tank was boiled and a new sending unit was installed. Some of the factory identifying tags are still on the engine, rear end, power steer pump and wiper motor. A new dual exhaust system was installed and has new quiet muffler and 2.5 inch exhaust pipes.
Moving to the inside of the car, the seats are extremely nice both the front and rear. I doubt anyone has ever sat in the back seat. Door panels are scratch free and are in great condition. Dash Pad on the car is CRACK FREE!!!!!!!!!! All lights work on this car. Headlights high and low, turn signals, license plate light even works. Dash lights and turn signals all work. The windows all roll up and down freely with out any noise or grinding. Both doors up and close and lock perfectly. Both high and low wiper motor works. Heater core was replaced along with a new dash heater switch and heater resistor are new. Stock radio is present and looks great but is not hooked up but wiring for it is present. The new black vinyl top was installed professionally by the guys at Auto Dynamix in Bellevue as well as the windows being re-sealed. Top is crisp and clean and is tight on the roof. The vinyl top trim was buffed and painted to refresh the look. The trunk on the car has been restored to factory fresh appearance with factory looking splatter paint applied and clear coated to protection and durability. Both the engine and trunk compartments have been detailed and are clean.
Magnum 500 chrome rims with NEW Cooper 225 70 14's are on the car with new Gran Torino center caps and new lug nuts. Car rides on these rims and tires.
The chrome shine on the front and rear bumpers are still amazing looking. Maybe at one time the original owner had the bumpers rechromed OR the car had to be in a garage its entire life to still have a gorgeous chrome shine to both bumpers. Straight and clean thees bumpers even have the bumperette's on them and they look great too. The car was undercoated heavily from the factory probably since the car was built in Seattle. The undercoating has preserved the underside of the car. Original Owner must have check the box of options of heavy undercoating to the option list. This undercoating is not something out of a spray can.
This car has had quite a overhauling and it shows.
"Non ci sono piccoli crimini.
Reati minori.
C'? solo la legge."
[Immagine: 28cf5nr.jpg]
"There's no such thing as a petty crime.
No minor infractions.
There's only the law."
[Immagine: 20jmo1s.jpg]
[Immagine: 24zwzrk.jpg]
[Immagine: 2ewd2le.jpg]
[Immagine: 2hxvxjt.jpg]
[Immagine: 2lvxmdj.jpg]
[Immagine: 25rz2u0.jpg]
[Immagine: keu8ao.jpg]
[Immagine: 10r92lw.jpg]
[Immagine: 2vb7mzk.jpg]
[Immagine: 2r77ksz.jpg]
Reati minori.
C'? solo la legge."
fantastica Smile non ho altre parole
non ho capito, tu vorresti comprare quest'auto a società??
- 1967 Buick GS400
Non importa se vinci di un centimetro o di un chilometro, l'importante è vincere...........
Sì esattamente, dividere le spese al 50% (o meno in caso di più interessati)
Reati minori.
C'? solo la legge."
mmmm.... e poi chi la usa??
- 1967 Buick GS400
la uso io :zsarcastic4xx:
[Immagine: firma.jpg]
Quello credo sia il minore dei problemi... comprandola assieme si mette in preventivo che può capitare la si voglia usare contemporaneamente... va all'onestà della persona, ci si organizza... non credo proprio sia un problema! D'altronde è un'auto in "comune", ci sono i pro (risparmiare) e i contro (può capitare serva ad entrambi). La cosa importante è non fare i pirl@ quando si è alla guida Wink
Reati minori.
C'? solo la legge."
Citazione:la uso io :zsarcastic4xx:
se la compri con me sì... la usi anche tu Smile
Reati minori.
C'? solo la legge."
Se devo essere sincero io un'auto non la comprerei mai in societa',perdipiu' se Si tratta di un auto d'epoca,quindi presa per passione,io sono del parere che:"l'auto e'come la moglie,non Si presta/divide con nessuno.
Poi son punti di vista.
C'è anche chi fa scambio di coppia o "cede" la moglie/compagna per guardare solamente :p
Come dici tu, sono punti di vista Big Grin ahahah
Reati minori.
C'? solo la legge."
Questo e pure vero!!! :-)
azzzz .. ma senti questi!!! :408:
Ma torniamo a lei, il fulcro della diatriba... avanti gente, coraggio! Sta aspettando solo noi Smile
[Immagine: 1ys3s3.jpg]
Reati minori.
C'? solo la legge."
Comunque,di essere Bella,e' bella,Su questo non Si discute,ma tradotto in euro,alla fine,macchina in garage,anche non immatricolata quanti euro ci vogliono?15k basteranno?
Citazione:Comunque,di essere Bella,e' bella,Su questo non Si discute,ma tradotto in euro,alla fine,macchina in garage,anche non immatricolata quanti euro ci vogliono?15k basteranno?
Io credo circa 7k auto e circa 7k (ma anche meno, dipende a chi ci si rivolge) trasporto sdoganamento tasse immatricolazione italiana chiavi in mano.
Inoltre questa è già pronta e restaurata, niente spese extra!!!
TOTALE 14.000
Reati minori.
C'? solo la legge."
Citazione:Se devo essere sincero io un'auto non la comprerei mai in societa',perdipiu' se Si tratta di un auto d'epoca,quindi presa per passione,io sono del parere che:"l'auto e'come la moglie,non Si presta/divide con nessuno.
D'accordissimo
Concordo in pieno.....
- 1967 Buick GS400
P.S.
Ma non è inserzionata a $22500???
- 1967 Buick GS400
Citazione:P.S.
Dove?!?!
Reati minori.
C'? solo la legge."
