Pure Stock Drag Racing - Versione stampabile +- Usa Cars Forum - Dreams on Wheels (https://www.usacarsforum.it/forum) +-- Forum: AMERICAN CARS (https://www.usacarsforum.it/forum/forumdisplay.php?fid=5) +--- Forum: American Racing (https://www.usacarsforum.it/forum/forumdisplay.php?fid=27) +--- Discussione: Pure Stock Drag Racing (/showthread.php?tid=4379) |
Pure Stock Drag Racing - funnycar - 27-09-11 Dal mese di aprile di quest'anno ? stata introdotta una nuova regolamentazione accettata da alcune piste americane. Mi sembra interessante soprattutto per il numero ridotto di regole imposte (in confronto alle 318 pagine del Rulebook NHRA) e per la possibilit? di ottenere tempi di rilievo (come mostra il sito di Hemmings proprio oggi). Le ripropongo cos? come sono formulate ed in "american language": a chi eventualmente avesse bisogno di chiarimenti dichiaro la mia completa disponibilit?. Ecco il testo integrale: Rules The most important rule: Your musclecar must be stock, except for the modifications outlined below. If a modification is not mentioned, keep it original! Remember, the goal is to have fun drag racing your musclecar. See old friends, make new ones, and enjoy all the cool cars on the track! For 1955 to 1974 musclecars built in United States and Canadian assembly plants with a minimum warranty of 12 months and 12,000 miles. Factory lightweight cars built for sanctioned drag racing and dealership-built/modified cars are not eligible to participate. Cars must be factory equipped with a minimum of four-barrel carburetion, dual exhaust, and other factory-installed equipment that promotes a high-performance intent and image. Cars are paired up based on time trial e.t.s and compete in a best-of-three heads-up shootout. Body The original appearance must be maintained. No aftermarket panels of any kind are allowed. No "custom" paint colors, designs, or lettering are allowed. The car must maintain the stock ride-height. Raising or lowering either the front or back of the car is NOT allowed. The car must have a presentable appearance. No primered areas, mismatched paint, or large rust-holes allowed. Bumpers must retain all original bracing and reinforcements. Inner fender panels, front and rear, must be retained. Factory hood scoops, ram air, and fresh air induction must be correct for the year, make, and horsepower claimed. No aftermarket or homemade induction units of any kind are allowed. The factory air cleaner and filter must be in place during all runs. Aftermarket air cleaners NOT allowed. Air cleaner lid can be raised no more than ?-inch off the base. Interior seating, trim, and materials must be correct for the year and model claimed, as well as being completely functional. Aftermarket tachs and gauges are allowed if mounted on the steering column or under the dash, except for some factory tachs mounted on top of the dashboard. All accessories must be functional (radio, wipers, heater, blower motor, turn signals, etc.). OEM glass only. All windows must be functional and closed during all runs. The trunk must appear stock at all times. Drivetrain Automatic Transmissions: The transmission must be correct for the year, make, model, and horsepower claimed. Shift improver kits are allowed. Aftermarket shifters are not allowed. No manual valve bodies. Lightweight purpose-built, drag racing transmissions NOT allowed (for example Pro Trans, Kilgore, etc.). Just switching to aluminum drums is illegal. Anyone caught will be banned from the event until corrected! Torque converters must be within 1 inch of the stock outside diameter. Maximum stall limited to 2200 rpm. Higher stall speeds will require factory documentation. Manual Transmissions: The transmission must be correct for year, make, model and engine of the car. 3-speed manuals may be upgraded to the correct 4-speed if originally available. Aftermarket H-pattern shifters are allowed if no modifications to the floorpan are necessary. Line locks are not allowed. Scattershields are okay. No conversions from column-shift to floor shift allowed unless available as a factory option. Aluminum flywheels are NOT allowed. Rear Axles: The rear axle must be of the same manufacturer as the car. Any gear ratio is allowed. Lightweight driveshafts NOT allowed. Driveshaft safety loops are mandatory on all cars 13.99 and faster! Spools of any kind are NOT allowed. Engine Engine: Must be factory correct for the year, model, and horsepower claimed. Dealer-installed engines and dealer-performed engine modifications are not allowed. Casting numbers must be correct for the year and horsepower claimed including intake manifold, heads, and exhaust manifolds. Head modifications are prohibited, including, but not limited to, porting, bowl cutting, gasket matching, oversized valves, etc. Heads can be cut to help achieve the allowed compression over advertised. Blocks do not have to be "numbers matching," but they must be the correct displacement. Overbores up to .070" are allowed. Stock cranks only. NO strokers! Random P&G checks are possible. Lightweight cranks and connecting rods are NOT allowed. If found, you will be banned from the event until corrected! Aluminum rods are NOT allowed. Smaller-than-stock rod journals are NOT allowed. Aftermarket pistons are allowed, but piston rings can be no thinner than 1/16", 1/16", and 3/16" for top, second, and oil rings, respectively. Gas porting of pistons NOT allowed. Metric and pressure-back-type rings (dykes, head land, etc.) are NOT allowed. Torque straps allowed. Compression Ratio Limits: All Engines ? 1.5 extra points allowed over advertised. Contact us so we agree on the advertised compression. a. Engines with factory dished pistons will be allowed to run either a smaller dish, a flat-top piston, or a small domed piston to achieve the maximum allowed compression. b. Engines with factory flat-top pistons will be allowed to run a domed piston to achieve the maximum allowed compression. c. Engines with factory domed pistons must run a dome of equal or greater dome volume than stock to achieve the maximum allowed compression ratio. d. Heads can be milled and blocks decked within reasonable limits in combination with a), b), or c) above to help achieve the maximum allowed compression ratio. Electrical System: The battery must be retained in the original location and securely fastened down with the original style hold down. The charging system must be fully operational at all times. The removal of the alternator belt is not allowed. Lightweight batteries are NOT allowed. Fuel System and Carburetor: The carburetor must be correct for the year, make, and horsepower claimed. Jetting and metering changes are permitted. THE CHOKE ASSEMBLY MUST BE IN PLACE AND FUNCTIONAL! Mechanical secondary carbs cannot be substituted if vacuum operated units were original to the car. Mechanical fuel pumps must be retained. Electric fuel pumps are NOT allowed. No fuel pressure gauges are allowed anywhere along the fuel system. Factory fuel lines are required and must be correct size. No rubber lines allowed unless originally equipped as such. No fuel cells are allowed. Pulleys: All pulleys must be factory issue and be correct diameters for the year and horsepower claimed for the engine. Belts running the water pump, alternator, and power steering must be retained at all times. Air conditioning belts may be removed if they do not affect other components. Valve Train: The valve train must be factory stock for the year, make, and horsepower claimed. Rocker arm ratio must be correct for the year and horsepower claimed. No aftermarket rocker arms of any kind allowed. Stock stamped steel or stock cast iron factory rocker arms only. Random requests for valve cover removal WILL happen. Poly-lock type adjustable nuts, jam (crimp) nuts, and adjustable pushrods are allowed. Valve covers must be correct for the year, make, and horsepower claimed. OEM-style replacement lifters only ? no trick racing lifters (i.e. ceramic) or shimmed (limited travel) hydraulic lifters allowed. Maximum valve spring SEAT pressure allowed is 130 pounds. Higher seat pressure will require factory documentation. Factory spring configuration must be retained; that is, if your car came with single valve springs, you must run single springs. If it came with dual valve springs, you must run duals. Beehive valve springs are NOT allowed. No aluminum or titanium valve spring retainers allowed. Camshaft: The camshaft must be correct for the year, model, and horsepower claimed for the type of lifter (hydraulic or solid). Roller cams NOT allowed. Duration at .050" lobe lift must be within 1% of factory specs. Lift at the valve must be within 2% of factory specs. Engines must be able to produce at least 16.0 inches of vacuum at 1200 rpm. However, some factory-produced engines were not able to generate 16.0 inches in showroom condition, so those cars will be given a variance to the rule. Solid-lifter cams lift checked at zero lash. Exhaust: Cast-iron exhaust manifolds are mandatory and must be correct for the year, model, and horsepower claimed. Internal modifications to the exhaust manifolds are NOT allowed. Under no circumstances will headers be allowed, including those cars that came with headers delivered in the trunk. The exhaust system may be upgraded to a maximum of 2.5-inch head and tail pipes. Pipes must be routed as they were originally for the year, make, model, and engine combination. Mufflers must be stock looking in design, that is, oval in shape. No glasspacks or straight pipes allowed unless installed as original equipment. Maximum muffler inlet and outlet size is 2.5 inches. X & H pipes allowed. Ignition System: The ignition system must be stock, including the distributor, cap, coil, and wires. Points may be replaced with any electronic conversion that fits under the stock distributor cap. Replacement coils are allowed as long as they are the correct shape, color, and size. Coils must be mounted in the correct location with correct brackets for the make, year, and engine combination. We will no longer allow the use of aftermarket ignition boxes like MSD, Crane, Jacobs, etc. We made this decision based on participants using these ignition boxes for traction and total timing manipulation while making runs. You will be allowed to use a rev limiter, but the unit must be only a rev limiter and nothing else. Spark plug wires must be of correct appearance in size and color for the vehicle. Cooling System: The radiator must be correct for the year, make, model, and horsepower claimed. No lightweight, aluminum radiators allowed. Overflow catch cans of at least 16 ounces are required. Radiator shrouds must be correct for the application. The fan must be factory original and correct for the year, model, and horsepower claimed. Aftermarket "lightweight" flex-fans are NOT allowed. Suspension Front Suspension: Stock springs and shocks must be retained. Drag race style springs, shocks, and bushings that allow excessive lift during launches are NOT allowed. The front sway bar must be retained, and it must be functional at all times. Raising or lowering of the front end is not allowed. Rear Suspension: Stock springs and shocks must be retained. Traction devices are limited to hop-stop bars for the upper control arms on coil-spring cars. Pinion snubbers and clamping of springs are allowed on leaf-spring cars. No slapper bars or ladder bars of any kind allowed unless originally equipped from the factory. Factory documentation will be required to prove authenticity for any car equipped with bolt-on traction devices. No dealer-installed traction devices allowed. Aftermarket upper and lower control arms for coil-spring cars are not allowed. Raising or lowering of the rear end is not allowed. Tires and Wheels: Reproduction tires or radial tires only. No soft compound tires of any kind allowed. Retread tires are not allowed. Use of traction compounds or rubber-softening chemicals on tires is strictly prohibited. Suspicious tires will be durometered. You are allowed to run tires one size over stock, with G70s being the largest size allowed for cars with 70-series tires, and G60s the largest allowed for cars that came with 60-series tires. All four tires must be the same size. No 60-series tires will be allowed unless they were originally available for the car's year and model. 60-series tires must be run on 15-inch rims as they were originally. Cars built before the introduction of 70-series Polyglas or Wide Ovals are allowed to upgrade to 70-series of appropriate size. Factory wheels only. Wheels must be correct in size, offset, and style for the car's make, model, and year. All four wheels must be the same size and offset. EXCESSIVELY WORN OR BALD TIRES ARE STRICTLY PROHIBITED! TIRES CANNOT BE WORN DOWN TO THE TREAD WEAR BAR INDICATORS. Suspected Violations, Required Tear Downs, and Banning from Race Deviations to any of the rules are grounds for disqualification, unless backed up with authentic factory documentation. Refusal to be teched in any area is grounds for disqualification. BANNED FROM THE RACE RULE! Starting in 2011, if we suspect that you are using lightweight internal parts in your engine or elsewhere in the drivetrain, or we have any other issues with your car, you will be asked to tear down prior to the next year?s race for complete inspection. If you refuse to do so, you will be banned from the race until you do. Safety Drivers must wear long pants. Cars 13.99 and quicker must have an approved Snell 2000 helmet! Batteries must be secured down. All cars must have seatbelts for the driver. All wheelstuds must be present and lugnuts tight. Radiators must have an overflow catch can of at least 16 ounces. All accessory belts MUST be in place and tight to operate the water pump, alternator, and power steering (A/C belt may be removed). Cars 13.99 and quicker must have a driveshaft safety loop! We highly recommend carrying a fire extinguisher in your car at all times. No passengers allowed in participating vehicles. Attention: Please Read 1. No passengers allowed in participating vehicles. 2. Wristbands for drivers mandatory. 3. Guest driver wristbands mandatory. 4. If you run faster than 3/10 during shoot-outs, you forfeit the shoot-out. Pure Stock Drag Racing - mopar - 27-09-11 Ma non fanno da anni la serie F.A.S.T. ? Factory appearing stock tires? la NHRA arriva solo adesso? Pure Stock Drag Racing - BLACK CAT - 27-09-11 wow... come mi piacerebbe provare !!!! Pure Stock Drag Racing - funnycar - 27-09-11 [quote name='mopar' post='378528' date='27/9/2011, 17:23']Ma non fanno da anni la serie F.A.S.T. ? Factory appearing stock tires? la NHRA arriva solo adesso?[/quote] Non ? esatto Antonello: F.A.S.T. ? effettivamente in vigore da tempo; N.H.R.A. ? effettivamente un po' lentina nel prendere le decisioni; questa ? l'ultima "trovata" per togliere la gente dalla strada. In effetti il mio intento sarebbe quello di proporre in Italia una regolamentazione non troppo farraginosa e facilmente applicabile SE ci fosse la voglia di accettare le regolamentazioni "complete" (anche se sintetiche): purtroppo pare non sia cos?. Il fatto ? che ne F.I.A. ne C.S.A.I. hanno ancora accettato il suggerimento (Carl Olson, delegato ACCUS-NHRA in FIA, 1993) di regole "tecniche" e classificazioni adatte alle vetture europee. Visto che di musclecars pare ne esistano non poche, in Italia...basterebbe tradurre ed applicare.... Pure Stock Drag Racing - mopar - 27-09-11 Non credo sia per il nobile intento di togliere gente dalla strada...ma per fare cassa su un fenomeno che alla NHRA non sono stati in grado di prevedere e reagire. La FAST ? in atto da almeno 5 anni, e quando hanno visto che si ? consolidata e i numeri che attraevano, allora si sono dati una mossa.... La Hills Race e la FAST sono la dimostrazione che le musclecar ci sono e che corrono, a dispetto degli organismi burocratici come ACI, CSAI e NHRA Pure Stock Drag Racing - bronzo - 27-09-11 Anche perch? non credo che ci sia ancora gente da togliere dalla strada con le muscle... magari con le tuning....ma le muscle ormai se ne stanno nei garage con i tempi che corrono... Pure Stock Drag Racing - funnycar - 27-09-11 @ mopar @ bronzo staremo a vedere che cosa succeder? in Italia "o' paese d'o mare e d'o sole" ........... Pure Stock Drag Racing - Guest - 29-09-11 [quote name='funnycar' post='378620' date='27/9/2011, 21:26']@ mopar @ bronzo staremo a vedere che cosa succeder? in Italia "o' paese d'o mare e d'o sole" ...........[/quote] Caro Franco, sai quanti bei progetti nascono e muoiono quasi subito, appena spunta il nome della famigerata Federazione Italiana X,Y o Z ? Non c'? verso, ogni tanto li punzecchiamo ma nulla, un muro di gomma e tante belle poltrone che tra l'altro si stanno svuotando, visto che l'et? media dei commissari e responsabili Federali ? sempre pi? alta, e non c'? ricambio. Non c'? n? la voglia n? l'interesse a sviluppare ci? che semplicemente, come dicevi tu, ? gi? tutto fatto. Basta fare un copia-incolla, applicarlo sul campo ed iniziare a farsi le ossa; invece che succede ? Investimento "zero", nessuna apertura verso realt? europee ben pi? collaudate (anche solo per fare della buona e sana esperienza), nessuno chiede aiuto a chi sta gi? cercando di investire nel settore ( "ma siamo matti ? ma da dove arrivano questi"...sembrano pensare guardandoli in faccia, ogni volta che li chiami a presiedere ad una gara come commissari tecnici/sportivi), nessuno che ha voglia di sperimentare sul serio. Praticamente peggio di un Ministero che ha interesse ad incassare qualche licenza, qualche gettone di presenza, qualche delibera di CDA che fa punti politici e niente pi?. Onestamente, visto il deludente risultato che, dopo oltre dieci anni, sta raccogliendo chi sta facendo del drag racing in Italia, ci vien da dire: investiamo su di un furgone affidabile, un bel carrello chiuso e via fuori confine. Capisco che dicendo questo, raffredder? i bollenti spiriti di chi sta aspettando solo che qualcuno faccia qualcosa di pi?, qu? da noi, ma non sono molto ottimista. O ci accontentiamo, o veramente ci conviene macinare dei chilometri, per correre con un po pi? di soddisfazione. Vabb?....stiamo a vedere che succede come dici tu. Alla prossima Pure Stock Drag Racing - funnycar - 29-09-11 Gli storici bene informati affermano che Napoleone fu sconfitto a Waterloo "perch? aveva mal di pancia" (a quanto pare da almeno un paio di giorni). Non c'entra nulla con la composizione degli eserciti, con la tattica e la strategia sul campo di battaglia, ma rimane il fatto che da quel giorno la Storia d'Europa cambi? per sempre a causa di dolori addominali sofferti da un Imperatore. Purtroppo "we did it for fun" (lo facevamo per divertirci) valeva dal 1920 al 1940: poi salt? fuori un uomo che ? stato definito "l'uomo giusto, al posto giusto, nel momento giusto". Certo che se le "thausand upon thausands" di amateur auto racers ("Throttle", rivista USA dal Gennaio al Dicembre 1941) gli avessero creato difficolt? "burocratiche" ad ogni pi? sospinto la N.H.R.A. non avrebbe compiuto nel 2011 60 anni ininterrotti di attivit? e non sarebbe il pi? grande Organismo sportivo motoristico al Mondo. La Passione ? una cosa indefinibile e, mi permetto aggiungere, anche incomprensibile ai pi?: quella vera, intendo. Ne consegue che presuppone (cio?: rappresenta un requisito iniziale ed indispensabile) anche l'assunzione di responsabilit?, non ultima quella di perseverare, anche andando contro l'opinione comune. Da sei anni si parla (o, meglio, io suggerisco) di un Organismo "autonomo" che ? possibile a norma di Costituzione Italiana, ma da Ottobre a Luglio "? meglio andare all'estero". Con questi presupposti mi chiedo: esister? mai un drag racing italiano? Pure Stock Drag Racing - BLACK CAT - 29-09-11 Funnycar : ma quali sono le difficolt? in italia ; burocratiche ? politiche delle organizzazioni ? non ci sono forse troppo poche vetture che potrebbero partecipare ? illuminami se puoi , grazie... Pure Stock Drag Racing - funnycar - 30-09-11 @ BLACK CAT In Italia, come noto ed arcinoto, le cose vanno "in una certa maniera": inspiegabile se non si inseriscono i presunti interessi del solito "qualcuno". Non ? noto, ad esempio, che due organizzazioni (che non nomino) pare appartengano a due schieramenti politici totalmente opposti, ma entrambe hanno interessi nell'automobilismo sportivo: una approfitterebbe del "monopolio" di fatto, l'altra sta cercando di minare questo strapotere. Il guaio ? che entrambe "non capiscono una pippa" di accelerazione (sport dell'accelerazione a motore). I Regolamenti attualmente approvati (vigenti) sono simili e contrapposti ma "totalmente inadeguati": in tutti gli sport praticati con un mezzo meccanico gli stessi mezzi sono classificati secondo una scala di valori che procede dal mezzo "di serie" fino al top della Formula 1 (che top non ?, a mio parere). Ovvio che le CLASSI specificano (dovrebbero specificare) le migliorie, modifiche "ammesse per regolamento" che dovrebbero essere verificate da Commissari Tecnici" competenti, prima di ammettere "in competizione" pilota (il quale a sua volta dovrebbe essere in possesso di Licenza ottenuta previo esame teorico, pratico e fisico) ed autovettura e motoveicolo. Non avviene e basta leggere i due Regolamenti per rendersene conto: ad esempio esiste una Classe Street e altra Top Fuel nel medesimo Regolamento, ma (e qui sta il problema) nessuna specifica tecnica precisa quali dovrebbero essere le caratteristiche in base alle quali i due veicoli saranno inclusi, ne quali parti specifiche debbano rispondere a certe caratteristiuche o con quali limiti. I commissari (di enntrambe le Organizzazioni) sono abituati a Rally o Fuoristrada o Veicoli d'epoca: sollevano il cofano, sbirciano il motore, puntano un dito chiedendo "che cosa ? questo" ed a generica risposta rispondono "...ah, ho capito"; pi? grave ancora compressore (turbo o volumetrico), impianti NOS (Nitrous Oxide System) e telaistica (ammortizzatori modificati, i famosi "ring" di ritenzione all'asse di trasmissione, differenziale e "misure degli pneumatici" fuori sagoma), tranquillamente ignorati. Negli U.S.A. vige in moltissime piste la regola dei 10.5 pollici di larghezza massima delle slicks, la proibizione assoluta di guida in competizione al di sotto dei 18 anni (due anni dopo il conseguimento della patente) e, cosa pi? importante, l'obbligatoriet? di rispettare la "massa minima regolamentare" in quanto le vetture vengono preliminarmente pasate prima di procedere alle verifiche. La patente (patentino sportivo) non ? conseguita dopo il versamento di una somma, ma dopo la visita medica ed uno specifico test attitudinale che pu? essere, in caso il veicolo sia stato modificato, il famoso "blindfold test": si sale in vettura (o moto) ad occhi rigorosamente bendati, si deve dimostrare di conoscere alla cieca i comandi principali (nello specifico: messa in moto se presente, lava del cambio, eventuale comando dell'estintore, leva dell'eventuale paracadute, cut off di alimentazione ed elettrico. A questo punto l'esaminatore pronunia un comando e l'asaminanando ha venti secondi di tempo per: sganciare le cinture di sicurezza, compresi gli arm-restrain (braccia legate), togliersi il casco ed uscire: se non esce in piedi dopo i venti secondi ? invitato a riprovare in data stabilita dai Commissari. Quanto alla consistenza reale di possibili Concorrenti non ho dubbi: quelli esperti sono per il 70% motociclisti; gli altri (automobilisti) sono stati fuorviati dal dilagare di regolamenti approssimativi ma molti, ancor oggi, devono essere istruiti sul "come" comportarsi prima e dopo essere arrivati allo staging, in quanto non hanno mai provato, sono ammessi in competizione e credono che sia necessario, anzi indispensabile, "pompare un pochino la macchina", comprare due mostruose slicks, "collare la pista" e si reputano, cos?, pronti a correre in una competizione. Nessun ragazzino di 10 anni pensa di poter essere immediatamente ingaggiato da una squadra di serie A, anche se gioca nella parrocchiale: questo ?, al contrario, il "principio ispiratore" dell'accelerazione all'italiana. Street Legal ? stata introdotta negli Stati Uniti circa vent'anni fa ma presuppone l'uso di "vetture regolarmente immatricolate ed assicurate nello Stato di appartenenza" (ovvero: se una pattuglia della Stradale ti fermasse, avresti tutto il diritto di sentirti dire: "Grazie si accomodi pure" mentre ti restituiscono patente elibretto). Siamo sicuri che tutte le vetture (e moto) siano "realmente" in queste condizioni? Pure Stock Drag Racing - funnycar - 30-09-11 Aggiungo solo un paio di "definizioni". Secondo quanto asserito da tecnici professionisti americani la drag race pu? essere cos? definita: "Il massimo della preparazione ed il massimo della velocit? espresse nel minor tempo possibile; comunque quanto non pu? essere espresso in altre discipline motoristiche". ?Dov?? quel tipo il quale sosteneva che la drag race ? una stupidaggine?? ? il titolo di un articolo dedicato ai "week-end warriors" (piloti della domenica): ? stato pubblicato su Car Craft nel numero di Agosto 2002. Ossia abbastanza recentemente e molto dopo di quanto sia presumibile la mia appartenenza ai "trogloditi" della cosiddetta vecchia guardia. La Frank Hawley Drag Racing School ha addestrato piloti quali Tony Shumacher e John Force "dopo che avevano gi? vinto" almeno un campionato: gli stessi hanno dichiarato che "dopo" hanno riscontrato "notevoli miglioramenti"...... Pure Stock Drag Racing - BLACK CAT - 30-09-11 Grazie mille Funnycar delle delucidazioni, tienici aggiornati... a presto ciao Pure Stock Drag Racing - t.bird - 30-09-11 [quote name='funnycar' post='379194' date='30/9/2011, 09:52']@ BLACK CAT In Italia, come noto ed arcinoto, le cose vanno "in una certa maniera": inspiegabile se non si inseriscono i presunti interessi del solito "qualcuno". Non ? noto, ad esempio, che due organizzazioni (che non nomino) pare appartengano a due schieramenti politici totalmente opposti, ma entrambe hanno interessi nell'automobilismo sportivo: una approfitterebbe del "monopolio" di fatto, l'altra sta cercando di minare questo strapotere. Il guaio ? che entrambe "non capiscono una pippa" di accelerazione (sport dell'accelerazione a motore). I Regolamenti attualmente approvati (vigenti) sono simili e contrapposti ma "totalmente inadeguati": in tutti gli sport praticati con un mezzo meccanico gli stessi mezzi sono classificati secondo una scala di valori che procede dal mezzo "di serie" fino al top della Formula 1 (che top non ?, a mio parere). Ovvio che le CLASSI specificano (dovrebbero specificare) le migliorie, modifiche "ammesse per regolamento" che dovrebbero essere verificate da Commissari Tecnici" competenti, prima di ammettere "in competizione" pilota (il quale a sua volta dovrebbe essere in possesso di Licenza ottenuta previo esame teorico, pratico e fisico) ed autovettura e motoveicolo. Non avviene e basta leggere i due Regolamenti per rendersene conto: ad esempio esiste una Classe Street e altra Top Fuel nel medesimo Regolamento, ma (e qui sta il problema) nessuna specifica tecnica precisa quali dovrebbero essere le caratteristiche in base alle quali i due veicoli saranno inclusi, ne quali parti specifiche debbano rispondere a certe caratteristiuche o con quali limiti. I commissari (di enntrambe le Organizzazioni) sono abituati a Rally o Fuoristrada o Veicoli d'epoca: sollevano il cofano, sbirciano il motore, puntano un dito chiedendo "che cosa ? questo" ed a generica risposta rispondono "...ah, ho capito"; pi? grave ancora compressore (turbo o volumetrico), impianti NOS (Nitrous Oxide System) e telaistica (ammortizzatori modificati, i famosi "ring" di ritenzione all'asse di trasmissione, differenziale e "misure degli pneumatici" fuori sagoma), tranquillamente ignorati. Negli U.S.A. vige in moltissime piste la regola dei 10.5 pollici di larghezza massima delle slicks, la proibizione assoluta di guida in competizione al di sotto dei 18 anni (due anni dopo il conseguimento della patente) e, cosa pi? importante, l'obbligatoriet? di rispettare la "massa minima regolamentare" in quanto le vetture vengono preliminarmente pasate prima di procedere alle verifiche. La patente (patentino sportivo) non ? conseguita dopo il versamento di una somma, ma dopo la visita medica ed uno specifico test attitudinale che pu? essere, in caso il veicolo sia stato modificato, il famoso "blindfold test": si sale in vettura (o moto) ad occhi rigorosamente bendati, si deve dimostrare di conoscere alla cieca i comandi principali (nello specifico: messa in moto se presente, lava del cambio, eventuale comando dell'estintore, leva dell'eventuale paracadute, cut off di alimentazione ed elettrico. A questo punto l'esaminatore pronunia un comando e l'asaminanando ha venti secondi di tempo per: sganciare le cinture di sicurezza, compresi gli arm-restrain (braccia legate), togliersi il casco ed uscire: se non esce in piedi dopo i venti secondi ? invitato a riprovare in data stabilita dai Commissari. Quanto alla consistenza reale di possibili Concorrenti non ho dubbi: quelli esperti sono per il 70% motociclisti; gli altri (automobilisti) sono stati fuorviati dal dilagare di regolamenti approssimativi ma molti, ancor oggi, devono essere istruiti sul "come" comportarsi prima e dopo essere arrivati allo staging, in quanto non hanno mai provato, sono ammessi in competizione e credono che sia necessario, anzi indispensabile, "pompare un pochino la macchina", comprare due mostruose slicks, "collare la pista" e si reputano, cos?, pronti a correre in una competizione. Nessun ragazzino di 10 anni pensa di poter essere immediatamente ingaggiato da una squadra di serie A, anche se gioca nella parrocchiale: questo ?, al contrario, il "principio ispiratore" dell'accelerazione all'italiana. Street Legal ? stata introdotta negli Stati Uniti circa vent'anni fa ma presuppone l'uso di "vetture regolarmente immatricolate ed assicurate nello Stato di appartenenza" (ovvero: se una pattuglia della Stradale ti fermasse, avresti tutto il diritto di sentirti dire: "Grazie si accomodi pure" mentre ti restituiscono patente elibretto). Siamo sicuri che tutte le vetture (e moto) siano "realmente" in queste condizioni?[/quote] come non quotarti, hai detto proprio tutto quello che si doveva dire. t.bird Pure Stock Drag Racing - funnycar - 01-01-12 Riprendo l'argomento per il nuovo anno (Auguri a tutti, per inciso), approfittando di quanto evidenziato da "Street Legal TV": leggete l'articoletto il cui link ? il seguente [url="http://www.streetlegaltv.com/features/editorials-opinions/mark-gearhart-we-need-a-uniform-set-of-rules-in-heads-up-racing/?utm_source=rss&utm_medium=rss&utm_campaign=mark-gearhart-we-need-a-uniform-set-of-rules-in-heads-up-racing"]http://www.streetlegaltv.com/features/edit...heads-up-racing[/url], e ditemi se sono troppe le Organizzazioni che "[color="#FF0000"]vogliono fare per conto loro[/color]". Meno male che non siamo inclusi nella lista (al contrario dei Paesi di cui si parla . |
