1966 Ford Mustang - Versione stampabile +- Usa Cars Forum - Dreams on Wheels (https://www.usacarsforum.it/forum) +-- Forum: LE VOSTRE AMERICANE (https://www.usacarsforum.it/forum/forumdisplay.php?fid=8) +--- Forum: Ford Motor Company (https://www.usacarsforum.it/forum/forumdisplay.php?fid=36) +--- Discussione: 1966 Ford Mustang (/showthread.php?tid=10643) |
1966 Ford Mustang - Guest - 13-07-06 mi s tanto che ? vero amore ....!!!! sono felice per te . 1966 Ford Mustang - Flaviospeed - 13-07-06 E spero vivamente che continui, sopratutto ora che potrei dedicare piu' tempo alla macchina... Comunque grazie #16! FORD SIX-SHOOTER 289/302 INDUCTION KIT Barry Grant "Six-Shooter" Tri-Power Induction package for Ford 289/302 engines. Renown for its impressive torque and horsepower characteristics, but also its simplicity. The "Six-Shooter" from Barry Grant runs reliably without constant attention, unlike many other three-deuce systems ,which demand frequent adjusting. The "Six-Shooter" kit of parts for the small-block Ford include: -(3) Demon 250 CFM two-barrel carburetors (with electric choke). -Intake manifold. -"Rush"Air cleaner assembly. -All necessary throttle linkages with fuel inlet logs and fittings 1966 Ford Mustang - Flaviospeed - 05-08-06 Che belli che sono i lavori fatti in casa!!! 1966 Ford Mustang - er wagone - 05-08-06 1966 Ford Mustang - Guest - 06-08-06 1966 Ford Mustang - bronzo - 06-08-06 BRAVOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 1966 Ford Mustang - caddy55 - 06-08-06 hei ma non ci sono le banane "blu ford"? 1966 Ford Mustang - Tarizza - 06-08-06 Almeno sai come occupare il tempo libero!!! 1966 Ford Mustang - Ricky426 - 07-08-06 1966 Ford Mustang - Flaviospeed - 07-08-06 [quote name='Tarizza' date='Aug 6 2006, 03:01 PM']Almeno sai come occupare il tempo libero!!![/quote] Piu' che altro ho mandato a quel paese tutti gl'altri impegni ... Spero di ****** il motore entro ****** **** (ho messo gl'asterischi per scaramanzia)! @Caddy Eh no... Ancora no! 1966 Ford Mustang - Guest - 07-08-06 [quote name='Flaviospeed' date='Aug 5 2006, 11:45 PM'][/quote] Sembra al patibolo!!!!!!Dagli una nuova vita Flavio!!!! 1966 Ford Mustang - Flaviospeed - 07-08-06 Certo! Nella coppa si vede benissimo il blu originale! 1966 Ford Mustang - Flaviospeed - 11-08-06 Abbiamo (io e mio padre) dovuto rinforzare il "patibolo" perche' la brutta curva che aveva fatto il tubo l'altra volta non ci piaceva per niente. Dopo averlo rinforzato per bene, abbiamo tappato altrettanto bene i buchi per passare alla prima pulita. Una passata veloce con l'idropulitrice, una bella passata con la benzina (pennellino alla mano), un sostanziale passata con la nafta (anche qui, pennellino alla mano) e una sciacquata con l'idropulitrice. Et voila' la prima pulita al motore: Che bello che e'! E non e' ancora pulito come lo voglio io!!! Prossimo passo, si tira giu' la coppa dell'olio e si costruisce il supporto per il radiatore... Che bello che bello che bello!!!! 1966 Ford Mustang - bronzo - 11-08-06 Bravo, bravissimo Flavio!!!!!! 1966 Ford Mustang - caddy55 - 11-08-06 sembra proprio in ottime condizioni, buon lavoro! 1966 Ford Mustang - Guest - 12-08-06 vai cos? broda 1966 Ford Mustang - Guest - 12-08-06 grande flavio!! come va con la carrozzeria??? 1966 Ford Mustang - Guest - 12-08-06 E il lavoro continua.. Per? i collettori sono pi? arrugginiti di quelli del mio trattore...Ma so ke li riporterai all'origine 1966 Ford Mustang - Flaviospeed - 12-08-06 La carrozzeria e' ferma perche' sono andati in ferie e perche' devo comprare alcuni lamierati nuovi (o usati ma in buone condizioni). I collettori sono cosi' anche per la temperatura. Dopo pochi km torneranno di quel colore comunque, va tutto via molto semplicemente. Si vede poco, ma nel collettore lato passeggiero, ho gia' pulito un pezzettino ed e' venuto bene. Grazie mille per tutti i complimenti!!!! 1966 Ford Mustang - Guest - 12-08-06 chebbella! |
