29-10-20, 03:11 PM
Vendo 2 cerchi nuovi, mai montati, mai usati.
Prezzo: € 600,00
Marca Cragar, modello S/S.
15" di diametro, 7" di canale.
Completi delle sue calotte e della confezione originale.
Dadi non inclusi.
Ecco le specifiche del costruttore, fate riferimento a queste per sapere se vanno bene per la vostra auto:
Wheel Diameter:15 in.
Wheel Width (in):7.000 in.
Wheel Bolt Pattern (app):5 x 101.6mm
5 x 4 in.
Wheel Material:Steel/Aluminum
TPMS Sensor Compatible:Yes
TPMS Sensor Mounting Style:Universal band mount
Primary Wheel Color:Chrome
Wheel Finish:Chrome
Manufacturers Wheel Series:Cragar S/S Super Sport Series
Offset:+3.00mm
Backspacing (in):4.125 in.
Wheel Construction:2-piece
Beadlock Included:No
Beadlock Functional:No
Lug Nut Seat Style:Conical seat - 60 degree
Hub Centric Ring Compatible:No
Center Bore Diameter (in):2.820 in.
Center Bore Diameter (mm):71.63mm
Center Cap Included:Yes
Lug Nuts Included:No
Small Diameter Lug Nuts Required:No
Valve Stems Included:No
The timeless styling of Cragar S/S Super Sport wheels is a great look for any American musclecar--old or new! Cragar 61C Series S/S wheels offer a classic 5-spoke pattern in a beautiful mirror chrome finish, making them eye-catching classics just right for your ride. Their composite construction features chrome plated steel rims mated to A356 aluminum alloy centers--no polishing is needed, leaving you more time for cruising! And these 61 Series original S/S designs afford you the advantage of direct bolt fitment in various widths and diameters. Give your muscle updated versions of the most popular wheels ever--Cragar 61C Series S/S Super Sport wheels.
Prezzo: € 600,00
Dadi non inclusi.
5 x 4 in.
Wheel Finish:Chrome
Offset:+3.00mm
